Commands Line Delay..
Aug 22nd, 2006
Hi all,
I'd like to monitor some devices using following commands..
router(#)term le 0
sh led
sh context sum
sh diag
sh cdp nei
sh int
sh env
sh ver
sh proc me
sh proc cpu
sh ip route sum
sh ip ospf da da
sh ip bgp sum
sh ip int bri
sh diag sum
sh idb
If I do like abobe, Is it okay ? If not, How can I get right Message ? I think line delay is the answer (?)
Welcome any post ...
TIA
Overall Rating: 2.5 (2 ratings)
jackyoung Tue, 08/22/2006 - 23:35
  • Gold, 750 points or more
If I understand correctly, you want to have the output of the mentioned command. What is the problem to execute those commands and get the result ?
Do you mean you want to run a script ? If yes, just ensure there is a "enter" after each command to make it like as enter to the router directly.
Hope this helps.
hyukin.kwon Wed, 08/23/2006 - 00:41
Right.. I want to play a script. If use a script, also If the output is long, I think the output is mix each other(?). Is there any good method ?
TIA...
grant.maynard Wed, 08/23/2006 - 00:25
  • Silver, 250 points or more
I think you mean you want a delay between each command. This is a function of your terminal software.
In HyperTerminal go to Properties - Settings - Ascii Setup and enter a Line Delay.
It's a good idea to put "term length 0" before the first command and "term length 24" after the last.
