Call rollover from gateway to gateway with SIP
pbogomolnyi
I am trying to make an outbound fax (from RightFax) roll over to GW#2 in case no PSTN trunks are available on GW#1. RightFax only supports SIP and I created a voip dial peer for destination 91T with preference 3 so it would take effect if pots dial-peers are unavailable. Debug dialpeer shows that GW#1 picks correct (SIP) dialpeer, but nothing shows on GW#2.
Any thoughts would be appreciated.
Pavel Bogomolnyi
Brandon Buffin
Try the following commands on GW#2:
enable
conf t
voice service voip
allow-connections sip to h323
exit
Hope this helps. If so, please rate the post.
Brandon
