Disable Wireless NIC
Aug 23rd, 2006
Do anyone know of any script that tweak the registry to disable the wireless NIC when both the wired and wireless NIC is detected.
In situation where both the wired and wireless NIC is enabled, we want a script that alter the registry key in XP to disable the wireless NIC and left the wired NIC alone.
Pls advise and thanks.
s.conway Sat, 08/26/2006 - 02:41
have you asked this on a Microsoft forum? You may have better luck getting an answer.
