Warning message
WLC Design Questions
Aug 25th, 2006
Looking for a "recommended" design.
Looking at a remote location that contains no Cisco switches or router. 5 AP's total. Seems kinda of pointless to setup a 4402 Controller for 5 AP's. What is the recommended REAP mode implementation (real world) for AP's? Other alternatives?
diro Fri, 08/25/2006 - 10:53
  • Bronze, 100 points or more
you could by a 2006 controller that supports up to 6 ap or a cisco isr with wireless controller module
svanhandel Tue, 09/05/2006 - 13:10
Thanks... Kinda of what I figured. This design does not scale well if the remotes all use between 3 - 5 AP's at each site. If you can't run these use REAP mode... What good is it?
claeysg Tue, 09/05/2006 - 23:30
Another option is to use hybrid-REAP but Cisco does not recommend to use hybrid-REAP when there is more than 3 Aps on the remote site.
Note: Hybrid-REAP is a new feature of the latest release (June 2006). This feature is also only supported on the 1131AG and on the 1242AG.
alois.heilmaier... Wed, 09/06/2006 - 09:28
be careful, you don't have infrastructure at the remote site ?
You can directly connect up to 3 APs to a 2006 controller. But I don't know, if you can use 1130/1240 APs because they are LWAPP-converted APs, so they only use L3-LWAPP. I think with L3-LWAPP there must be an L3-Link between AP and controller, but I am not sure. By the way POE is an extra, controller 2006 has no POE enabled Ports.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
