Warning message
Relationship between ppp multink & dialer load-threshold
Aug 28th, 2006
My question goes to the relationship between ppp multink and the dialer load-threshold command in an isdn ddr configuration. If we use ppp mutlink on the bri without dialer load-threshold will both b channels become immediately active or is this purpose of dialer-load threshold here to only activate 2nd channel per criteria established by dialer load?
spremkumar Mon, 08/28/2006 - 03:14
  • Red, 2250 points or more
Hi Steven
You need to have dialer load-threshold command configured to bring additional channel though you have configured ppp multilink.
regds
stevennowell Mon, 08/28/2006 - 03:29
So does this mean that 2nd b channel will never be activated in mpp config without this command? MPP config without dialer-load thresh will never use 2 channels ?
spremkumar Mon, 08/28/2006 - 03:35
Hi Steven
Though i haven't tried yet running without threshold command ,AFAIK it doesn't fire the second channel without the command...
Regds
sundar.palaniappan Mon, 08/28/2006 - 16:43
  • Green, 3000 points or more
Actually, there's another way to bring up the 2nd b-channel without using the 'dialer load-threshold (number)' command.
R1(config)#int bri1/0
R1(config-if)#ppp multilink links minimum ?
<0-255> Specify minimum desired number of links in a bundle
R1(config-if)#ppp multilink links minimum 2
With this command in there the router would always attempt to keep a minimum of 2 b-channels active at any given time.
You can find more info here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tdia_r/dia_p2ht.htm#wp1008843
HTH,
Sundar
