hani_altaher Mon, 08/28/2006 - 05:37
if i want to use dial peer for routing call when WAN failoure do i need H323 configuration or MGCP (MGCP call fallback and application default ,alteran app)?
jslagle77 Mon, 08/28/2006 - 07:33
To start you will need to have at least something to this effect on a MGCP gateway:
General SRST GUIDELINES - Basic
application
global
service alternate Default
ccm-manager fallback-mgcp
dial-peer voice 1 pots
preference 1
service mgcpapp
destination-pattern 9T
progress_ind setup enable 3
incoming called-number .
direct-inward-dial
port 0/0/1:23
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7940 2
limit-dn 7960 4
ip source-address (Gateway IP Address)port 2000
max-ephones XX
max-dn xxx dual-line preference 1
system message primary Phone System Fallback
voicemail XXXXXXXXXX
This is just a start and you will need to customize it to fit your environment. But this will at least get you started....
hani_altaher Mon, 09/04/2006 - 23:05
thank you very much for your assistance.but i used H323 only So can H323 configurations to be sufficient for SRST to work as Expected without MGCP configuration
