Warning message
VPN 3000 Software question ???
Answered Question
Aug 28th, 2006
Hello all,
i have a question about the software for the VPN 3000 .on the cisco side i found last week the new 4.2.7.I from 03-AUG-2006 and now i found a newer one with vpn3000-4.1.7.O-k9.bin from 15-AUG-2006.
this is a little bit confusing for me.
can anyone explain me what to use for a VPN Conc 3030 with 128mb mem?
thanks in advance
Klaus
Correct Answer by mmasha about 10 years 11 months ago
What is your VPN-server hardware part number if it support 3DES you can use vpn3000-4.1.7.O-k9.bin otherwise no.
Overall Rating: 5 (1 ratings)
Correct Answer
mmasha Mon, 08/28/2006 - 09:54
ksimsimon Tue, 08/29/2006 - 01:12
Hi mmasha,
ok thanks for the answer.i have checked this and yes we have 3DES.now i have upgraded both concentrators and it works.
thanks for your help.
regards
Klaus
Jacob-Harris Tue, 09/19/2006 - 04:49
Can anyone explain the differences between the 2 code streams? What are the differences, vulnerabilites in the code levels? and what is the recomended upgrade? Are there new release scheduled soon we should wait on?
sactoraymond Wed, 09/20/2006 - 09:32
Not 100% sure, but my impression is that the 4.7.x series have more to do with WebVPN and SVC (activeX vpn client) featues. Can someone confirm this?
