Block hosts to communicates
Answered Question
Aug 28th, 2006
anyone can help me find the command to use to deny any host to communicate with an other connected at the same access point?
I have a 1231 Aironet AP.
Omar,
Correct Answer by jolmo about 10 years 11 months ago
Hi Omar
under "interface Dot11Radio0" use:
bridge-group 1 port-protected
For more info:http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a00801d0179.html#wp1038494
Hope this helps
Overall Rating: 5 (2 ratings)
scottmac Tue, 08/29/2006 - 04:18
  • Green, 3000 points or more
In the WebGUI, under the radio config, there's a checkbox labeled "Public Secure Packet Forwarding (PSPF) ... checking that (enabling it) will prevent a client of the access point from accessing another client on the same access point.
Good Luck
Scott
Trending Topics - Security & Network
