Warning message
Upgrade from CCM 3.3(3) to 3.3(4) failed
Aug 29th, 2006
Hi cant upgrade my ccm from 3.3(3) to 3.3(4)or any other version.
Here s the error in the log :
=== Logging stopped: 8/29/2006 21:46:09 ===
MSI (c) (50:60): Product: Cisco CallManager -- Configuration failed.
08/29/2006 21:46:09.589 CCMSetup.cpp fnRunCommand CreateProcess returned: 1603
08/29/2006 21:46:09.589 CCMSetup.cpp fnRunCommand Function ended
08/29/2006 21:46:09.589 CCMSetup.cpp fnInstallPackage msiexec.exe: Return Code: 1603: Fatal error during installation.
08/29/2006 21:46:16.902 CCMSetup.cpp fnInstallPackage Cisco CallManager Upgrade did not complete successfully. Review the log file for more information.
08/29/2006 21:46:16.902 CCMSetup.cpp fnInstallPackage User responded "OK" to message box.
08/29/2006 21:46:16.902 CCMSetup.cpp fnInstallPackage Function ended
08/29/2006 21:46:16.902 CCMSetup.cpp WinMain Function ended.
Any idea ?
Nicolas
gogasca Tue, 08/29/2006 - 07:30
  • Green, 3000 points or more
The installation is not proceeding in the PUB or in the SUB?
Make sure you have run Upgrade Assistant and
LMHOSTS|HOSTS files are configured correctly.
Windows path environment path is not correct. So the isntaller is unable to save the dc
database.
It could be incorrect DNS entree that maybe preventing it from properly installing it.
It could be that you running into
CSCee81635 bug below are the details.
If the problem is after installing CallManager, DCDirectory service fails to start giving a logon failure error message.
Conditions:
If windows administrator password has any of the following 4 characters, this
problem will surface.
Workaround:
Change the windows administrator password to remove the one or more special
characters mentioned above from the windows administrator password and reinstall CallManager.
