No dhcp address
Aug 29th, 2006
I setup some ap1100 with a native vlan and VLAN for wireless clients. Setup trunking on the swtich set the ip address fron the dhcp as the ip helper address but the clients get no ip address.
no aaa new-model
dot11 vlan-name vlan14 vlan 14
dot11 vlan-name vlan16 vlan 16
dot11 ssid AMADEUS-1
vlan 14
max-associations 20
authentication open
mobility network-id 14
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit
encryption mode wep mandatory
encryption vlan 14 mode wep mandatory
ssid AMADEUS-1
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
power local cck 2
power local ofdm 2
power client 2
channel 2472
station-role root
payload-encapsulation dot1h
interface Dot11Radio0.14
encapsulation dot1Q 14
no ip route-cache
bridge-group 14
bridge-group 14 subscriber-loop-control
bridge-group 14 block-unknown-source
no bridge-group 14 source-learning
no bridge-group 14 unicast-flooding
bridge-group 14 spanning-disabled
interface Dot11Radio0.16
encapsulation dot1Q 16 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption key 1 size 128bit 7
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.14
no ip route-cache
bridge-group 14
interface FastEthernet0.16
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.16.242 255.255.255.0
no ip route-cache
ip default-gateway 192.168.16.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
control-plane
bridge 1 route ip
wlccp ap username
wlccp ap wds ip address 192.168.10.245
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
andrew.brazier@... Tue, 08/29/2006 - 05:37
  • Bronze, 100 points or more
Usually indicates that the client hasn't authenticated with the AP correctly and if using static WEP (which I think you are) that the WEP key is wrong somewhere. Re-enter on the AP and clients and try again.
jefvaneijk Tue, 08/29/2006 - 06:53
Wel is see that the client is Associated, i think somewhere the client cannot reach the dhcp server
drees Tue, 09/05/2006 - 04:51
You will see an association, but no authentication if the WEP key doesn't match. Type the wep key into both client and AP again. WEP key shouldn't be pasted into an AP. I've seen issues with this. Make sure you use the same index on both ends.
Good Luck,
Dave
vleonard Fri, 09/15/2006 - 08:13
You might try removing the "mobility network-id 14" under the SSID.
I just upgraded about 60 AP-1231 and none of the clients that tried to connect to a SSID that had that command would get an IP address.
I had upgraded to 12.3(8)JEA.
The old IOS was 12.3(7), 12.3(8)JA and a couple other older versions.
richkrissi Fri, 09/15/2006 - 15:14
I would double check your trunked on the port your ap is connected to. Also ensure that port is tagged to your vlans. Make sure your DHCP server can tracert to that vlan.
When I see this,usually it is a misconfigured switch port.
