unable to contact switch attached to a stack of switches
Aug 29th, 2006
situation:
4 switches connected via a stack ( GIGASTACK cable )
1 switch attached via ethernet
VLANS are configured on all switches and default gateway is set correct
TRUNK is configured with the necessary VLAN ID's on all intermediate devices.
problem:
I'm unable to reach the ethernet attached switch while I am able to reach the stack of swithes.
I'm able to reach all switches in the stack from the ethernet attached switch
I'm able to reach the default gatewy which is contacted over the TRUNK.
What is wrong ???
Edison Ortiz Tue, 08/29/2006 - 06:53
  • Hall of Fame,
    Founding Member
Can we see switch configs along with show vtp status and show vlan ?
jackyoung Tue, 08/29/2006 - 22:57
  • Gold, 750 points or more
Is that mean the 10.33.5.11 behind 10.32.254.1/2 device ? What is the device w/ IP addr 10.32.254.1/2 ? It looks like this device did not know how to return the packet back to SUNCISCO6.
Do you mean you can ping to 10.32.254.1 from SUNCISCO6 too ? Can you ping to 10.32.254.2 from SUNCISCO6 ?
jackyoung Tue, 08/29/2006 - 18:24
Please provide the config. Did you enable VLAN routing at switch ? Is the traffic can't pass via different VLANs or same VLAN.
Please also show us the test result, e.g. trace or ping test.
Thx.
vancampdax Wed, 08/30/2006 - 07:48
suncisco4#ping
Protocol [ip]:
Target IP address: 10.33.5.11
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.32.50.24
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.33.5.11, timeout is 2 seconds:
Success rate is 0 percent (0/5)
suncisco4#ping
Protocol [ip]:
Repeat count [5]:
Source address or interface: 10.32.254.7
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
why isn't VLAN11 ( 10.32.50.x ) using the added routes to forward the packets ?
How can you determine which interface is used to forward packets ?
Edison Ortiz Wed, 08/30/2006 - 08:04
  • Hall of Fame,
    Founding Member
Dax,
Please post config from device (10.32.254.1).
jackyoung Wed, 08/30/2006 - 16:57
According to the ping test result. I belive there is no route for the 10.32.50.24 in 10.33.5.11's GW.
Just like Edison's said, we need the config. of 10.32.254.1.
Moreover, please also provide the suncisco4 config. And what is the GW in 10.33.5.11 ? If it is not 10.32.254.1, please also provide the config. of the GW.
vancampdax Wed, 08/30/2006 - 22:52
OKE,
To make some thing clear
There is NO default gateway for the subnet 10.32.50.0/24 network, but this is not necessary beacause this is an isolated, not routed subnet,.
management will be done via the newely created 10.32.254.0/24 network.
I can't give the configuration from the 10.32.254.1 device, but I can say taht this is our layer 3 backbone switch.
Edison Ortiz Thu, 08/31/2006 - 06:43
  • Hall of Fame,
    Founding Member
Dax,
Can you provide a drawing of your physical network ?
Can you also provide the config from 10.32.254.1 device ?
Without this information, I believe I can't help you further.
jackyoung Thu, 08/31/2006 - 16:36
What I mean is the 10.33.55.1's GW have the route to 10.32.50.0/24 or there is a default route there.
If 10.32.50.0/24 is an isolated segment, why you try to ping from this subnet to 10.33.55.1. The failure is correct result.
Please provide a diagram and specify your traffic flow requirement then we can list out what you need to do. Otherwise, it can't provide additional help.
Hope this helps.
