Warning message
ASA 5510 7.1.2(12) SSL VPN and Mac OS x
Aug 29th, 2006
Hello. I'm trying to find out if the SSL VPN on an ASA (5520 not 5510) supports Mac OS? I've read that the VPN3000 can do it, but can't find a definative answer if the ASA supports it. If anyone is making it work, is there anything special you need to do on the Mac?
Keith
Overall Rating: 3 (1 ratings)
ftikphillips Fri, 09/01/2006 - 03:59
In the ASA5520 I am testing I have connected with SSL from the MAC OSX. You do lose Secure Desktop though.
ftikphillips Fri, 09/01/2006 - 05:15
Just wanted to add more input. From Mac OS and Linux you can SSL into the ASA, but you do not get the full tunnel client like you do on Windows. You do get via the portal, web browsing, file access, and port forwarding. You also get cache cleaner.
