many clients share a VPN tunnel
Aug 31st, 2006
Deal all,
how do we configure a VNP tunnel that can be shared by many users? How do we make sure that all users use the same tunnel and not each user creates each tunnel to remote peer?
could someone help please,
many thanks
spremkumar Thu, 08/31/2006 - 04:17
  • Red, 2250 points or more
If i have understood your query properly its all about the routing you do in the router.
The routes you add and the traffic which you want to get encrypted.
you need to apply encryption for the interesting traffic (usually the your lan transactions between your locations).
So its upto you to route the traffic towards the interface which is applied with the crypto map and also the same is mentioned in the ipsec policy.
if its a normal GRE tunnel you simply need to route the traffic via the GRE tunnel so that the encapsulation can be applied on your packets.
regds
