Port mirroring on 3550's in stack
Answered Question
Aug 31st, 2006
Hi all,
I have two 3550's connected in a stack using gig ports. I wanna moniter port fa0/1 of switch one and fa0/1 of switch two traffic on port fa0/4 of switch one. I wanna to know if i can configure RSPAN to do that. Please let me know how to do it. Thanks for your help
Correct Answer by leonvd79 about 10 years 11 months ago
Yes, what you want is possible with RSPAN.
Create a RSPAN VLAN, let's say VLAN 500 on both switches.
conf t
vlan 500
remote-span
end
Configure the port you want to copy frames from into the RSPAN VLAN.
monitor session 1 source interface FastEthernet0/1
monitor session 1 destination remote vlan 500 reflector-port FastEthernet0/24
Finally configure a session that copies the frames from the RSPAN VLAN into the port with sniffer attached.
monitor session 2 source remote vlan 500
monitor session 2 destination interface FastEthernet0/5
Verify your configuration.
show monitor session all
--Leon
* Please rate posts.
Overall Rating: 5 (2 ratings)
Correct Answer
leonvd79 Thu, 08/31/2006 - 22:53
  • Silver, 250 points or more
conf t
vlan 500
remote-span
end
--Leon
vemulabhanu Thu, 08/31/2006 - 23:21
Hi Leon
Thanks for your reply. I have small confusion here. My problem is
Switch 1 and switch 2 (3550's) are connected in a stack using gig ports. Now I want to moniter ports fa0/1 of both the switches on fa0/4 of switch 1. So is it possible to keep fa0/1 of switch 1 in the RSPAN vlan. My IDS is connected to port fa0/4 for switch 1. SO i want to send all the traffic on fa0/1 of both the switches in stack to fa0/4 of switch 1. If so could you please let me know the configuration.
Thanks for your help.
Bhanu
leonvd79 Thu, 08/31/2006 - 23:32
Hello Bhanu,
The configuration is quite simple.
Switch 1
vlan 500
remote-span
exit
monitor session 2 destination interface FastEthernet0/4
Switch 2
vlan 500
remote-span
exit
Switchport Fa0/1 frames are copied onto VLAN 500 by reflector-port Fa0/24 on both Switch 1 and Switch 2. On Switch 1 the frames are copied from VLAN 500 to Fa0/4 where your IDS resided.
--Leon
vemulabhanu Fri, 09/01/2006 - 15:03
Hi Leon
I for it done and thanx for your kind help. Keep going on
Bhanu
