Router Static NAT Issue
Sep 1st, 2006
We hv a network as per attached topology diagram.
Topology:-
Public Segment via Internet Leased Line and Private segment via point to point link between Internet Router and Private Router
Enabled static NAT on Internet router for Private Segment Sever (172.16.2.151) but unable to ping or browse to external world from the Natted Server.
Attaching the config for both the internet router as well as Private router.
Do i need to add any interface level nat commands or it will work.
Pls advise.
regards
Overall Rating: 5 (1 ratings)
vijayasankar Fri, 09/01/2006 - 00:46
  • Silver, 250 points or more
Along with the current configuration, You should configure "ip nat inside" ( in the private segment) and "ip nat outside" ( in the ouside segment) as follows.
interface FastEthernet0/0
description Connected to Private Segment
ip address 199.30.1.10 255.255.255.0
ip nat inside
duplex auto
speed 100
interface FastEthernet0/1
Connected to Public Segment
ip address 220.227.194.193 255.255.255.248
ip nat outside
duplex auto
speed auto
Only then nat will work.
-VJ
fmatrine Fri, 09/01/2006 - 01:17
Thanx for the suggestion...
But my private server is in 172.16.2.x network and not 199.x.x.x segment.
Also second ethernet of Internet router is Public IP...once traffic arrives on the internet router from the private segment...won't it get natted statically on the public ip and go out.
Pls advise.
DB
vijayasankar Fri, 09/01/2006 - 01:27
In this case you should have the following config.
interface Serial0/0/0
Description Connected to Private_Router
ip address 192.168.165.30 255.255.255.252
ip nat inside
interface Serial0/0/1
Description Connected to Service Provider
ip nat outside
ip nat inside source static 172.16.2.151 220.227.194.197
Traffic from internet destined to the ip 220.227.194.197 will hit the serial interface 0/0/1 of your internet router. Here the nat translation should happend and convert the destination address to 172.16.2.151.
You need to have the "ip nat inside" and "ip nat outside" statements under proper interface to instruct the router how and when to NAT. With out which, your "ip nat inside source static..." command will not take effect at all.
-VJ
vijayasankar Fri, 09/01/2006 - 01:32
Additional info.
The IP 220.227.194.197 is a part of 220.227.194.192/29 subnet,which is located in the Fastethernet 0/1 of your internet router.
Hence Ensure that this ip 220.227.194.197 is not used by another system in this segment. You should not use this IP, as long as it is used for NAT.
-VJ
