user session timeout on PIX 6.3
Sep 1st, 2006
Good day!
We have PIX 6.3(4) and use it as VPN gateway (pp2p and ipsec clients). User authentication is via RADIUS.
How to set session timeout on each user?
On vpngroup it is done through a command
"vpngroup max-time ...", but it extends on all user connected by IPSEC client and this group. But we want to set different value of session timeout to different user.
I tried to use reply item "Session timeout" on radius, but nothing happened (the user remains connected as far as he wants)
And one more question...
How can i disconnect vpn user from pix using CLI or snmp or something else?
but only one user,the others should remain connected!
Thanks!
smalkeric Thu, 09/07/2006 - 06:39
  • Silver, 250 points or more
During a TFTP download, if tracing is on, non-fatal errors appear in the midst of dots that display as the software downloads. The error code appears inside angle brackets. If the error code is one then the error is Timeout between the PIX Firewall and TFTP server.
