Warning message
Cat3750 temperature
Sep 3rd, 2006
We are running 3750 ((C3750-IPBASE-M), Version 12.2(25)SEB4).
show env temperature
TEMPERATURE is OK
Is there an OID that we can get to snmp monitor the switch temperature?
pppyyyppp Sun, 09/03/2006 - 22:24
[root]# snmpwalk -c xxx 1.1.1.1 .1.3.6.1.4.1.9.9.13.1.3
enterprises.9.9.13.1.1.0 = 13
enterprises.9.9.13.1.4.1.2.1004 = "Switch#1, Fan#1, Status is Normal "
enterprises.9.9.13.1.4.1.3.1004 = 1
enterprises.9.9.13.1.5.1.2.1003 = "Switch#1, PowerSupply#1, Status is Normal, RPS Not Present"
enterprises.9.9.13.1.5.1.3.1003 = 1
enterprises.9.9.13.1.5.1.4.1003 = 2
I am actually looking for a temperature value / reading (say the temp of the switch is x deg C). Pls advise how to do about getting the temp readings.
n.bowbridge Mon, 09/04/2006 - 21:19
  • Bronze, 100 points or more
I'm running into the same problem. From what I can find researching on cisco.com the 3750 isn't capable of returning a temperature reading other than OK or alert. According to the 3750 config guide temperature can be monitored with the following command, but as you can see below even with the latest IOS it's unsupported.
Switch#sh env temperature status
Temperature Value: Not Supported
Temperature State: Not Supported
TEMPERATURE is OK
http://www.cisco.com/en/US/customer/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00802c10ce.html#wp1208309
sharptroubleshooting Thu, 09/05/2013 - 13:11
All I know is I have this:
cisco WS-C3750V2-48PS (PowerPC405) processor (revision E0)
Processor board ID FDO1348Z1SZ
Model revision number           : E0
Motherboard revision number     : A0
Top Assembly Part Number        : 800-31041-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMGW00ARA
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750V2-48PS    12.2(50)SE4           C3750-IPBASEK9-M
and can do this:
ABN-I014-G#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 50 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 66 Degree Celsius
Red Threshold    : 76 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   <>              <>
paolo bevilacqua Thu, 09/05/2013 - 13:20
  • Hall of Fame,
    Founding Member
Just to let you know, you're responding to a 7 years old thread.
