Warning message
sachinraja Tue, 09/05/2006 - 02:59
  • Red, 2250 points or more
mukhtar,
you can refer to the following document:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_guide_chapter09186a00800915d0.html
you need to define the community strings and configure the same on the LMS 2.2 box to capture the inventory, software, configuration etc....
Hope this helps.. all the best.. rate replies if found useful..
Raj
