Warning message
vigleik Sun, 11/05/2006 - 23:37
What if authentication fails, or the PC is not configured for 802.1X ; can the port then give access to a guest vlan or default vlan like we can with other Cisco switches ?
Vigleik
amit-singh Mon, 11/06/2006 - 03:20
  • Blue, 1500 points or more
You can do the vlan arrisgnment using 802.1x on CE500. The configuration for 802.1X and Radius authentication server can be done with the help of Cisco Network Assistant (CNA). In the menu Network Security Settings you have to put the
security level on high. There is the possibility to configure the IP address of the RADIUS server and the RADIUS key.
In case you don?t have the CNA, you can download it for free from:
http://www.cisco.com/cgi-bin/tablebuild.pl/NetworkAssistant
HTH, Please rate if it does.
-amit singh
