Edison Ortiz Tue, 09/05/2006 - 07:15
  • Hall of Fame,
    Founding Member
From the specs, they all support 4000 VLAN IDs, however you must keep in mind that VLAN 1006-4094, will not be propagated via VTP and they must be created manually on each switch and the switch must be set to VTP transparent.
anton.elita Tue, 09/05/2006 - 22:45
you shoud check not only VLAN limits for every device, but as well PVST instances limit (if you use PVST, of course). No worries with MST :)
anton
