WLSE failed to authenticate with WDS
Sep 5th, 2006
I've been beating myself in the head trying to figure this one out and I'm sure it's an easy one. I keep getting a "WLSE failed to authenticate with WDS" error for my primary WDS APs in all my sites with a couple of exceptions. We have a second WLSE that runs a few other sites that is not having this problem using the same account for WLCCP authentication in WLSE. Does anyone have an idea of what I could be doing wrong?
My WLSE version is 2.12 and I have 1210 APs running 12.3(7)JA2.
Any help is appreciated! Thanks in advance!
Rob Huffman Tue, 09/05/2006 - 09:52
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jason,
Have you tried this;
Enter WLCCP Credentials for Wireless Domain Services (WDS)
To configure the WLSE to authenticate with WDS devices, perform the following steps:
Procedure
Step 1 Select Devices > Discover > Device Credentials > WLCCP Credentials.
Step 2 Enter the Radius User Name and Radius Password.
This is the username and password that you set for the WLSE on the AAA server.
Step 3 Click Save.
From this 2.12 doc;
http://www.cisco.com/en/US/products/ps6379/products_installation_guide_chapter09186a008052dc6f.html#wp1108426
Hope this helps!
Rob
Please remember to rate helpful posts.....
jnaglich Tue, 09/05/2006 - 10:05
Hi Rob,
Yeah, I originally had that radius username and password that was set on the AP for the wlccp config in for the WLSE WLCCP Credentials, but that wasn't working. I then tried to use a radius account that I made specifically for the WLSE to do administration on the WDS APs, but that's not working either. I'm using Cisco ACS boxes for Radius.
Jason
diro Wed, 09/06/2006 - 11:28
  • Bronze, 100 points or more
is your wds in managed state on the wlse?
seesquinaldo Wed, 09/06/2006 - 13:05
I am also having this problem. My WLSE is also running software ver 2.12FCS. My SNMP strings on the WLSE match what's on the AP, but when I run a discover i get that the AP was SNMP unreachable. This AP is on the network and is the WDS for about 4 other APs.
jnaglich Wed, 09/06/2006 - 13:50
Yes - all my WDS APs are in a managed state.
Jason
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
