Warning message
csim start 957346946 ..... command
Sep 5th, 2006
Hi all I don't know why reason since some time ago this command doesn't work on my router I have 3845 with 12.4(3c) aso i need to run some test from this box
Some idea ?
I received the follow error :
router#csim start 957346946
csim: called number = 957346946, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(16) minor(0)
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 0
cheers
gogasca Tue, 09/05/2006 - 14:15
  • Green, 3000 points or more
"CSIM START" is a hidden command and is not officially supported by TAC. Having said that, there are known issues with using CSIM start with certain telnet clients and also using SSH.
It works when connected via Console or have you tried other Clients?
A normal call work right? Only csim is failing?
Per the number are you using E1 R2 or which protocol?
eduardo.ramirez Tue, 09/05/2006 - 16:48
Hi gogasca thanks for your response
In Fact you are right here in the company recently we implemented SSH as transport and the client that we re using is putty.
I back this box at Telnet so now is working fine this DOS client works 100 % with CSIM.
About your other questions all is working ok but you know this command is very helpful for the voice troubleshooting.
So anyway thanks for you support.
Note: if there you have the links about this issue please sent to me.
Saludos
