Warning message
Catalyst 4500 series Line card 4524G-24 POE
Sep 5th, 2006
Hi Pros,
Please help me to solve the below issue
- The POE line card module 4524 in the 4510R switch is not suppling the power to the Cisco phone (cp-7912G) and AIR-1230B wlan access point.
I already tried #hw-module power to enable the module and slot and #power inline auto to the specific interface.But still the module POE LED is off.
Could you give me the steps to bring the module POE enable. Now for timebeing using 3550 POE switch.
swamy
jolmo Wed, 09/06/2006 - 00:15
  • Silver, 250 points or more
Hi Swamy
Are you saying POE module is off?
Perhaps first you should check if your IOS version supports this module. Can you post the output from "sh ver" and "sh mod" ?
arumugasamy Thu, 09/07/2006 - 06:06
Dear Jolmo,
I had gone thro the datasheet for 4500 series power supply and found that the 1400Watts AC is for data only not included POE. 1300, 2800 supports both Data and POE.
I hope that due to this
The following message
RUWCore1#sh power
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-1400AC AC 1400W good good n.a.
PS2 PWR-C45-1400AC AC 1400W good good n.a.
Power supplies needed by system : 2
Power supplies currently available : 2
Power Summary Maximum
(in Watts) Used Available
System Power (12V) 575 2473
Inline Power (-50V) 0 0
Backplane Power (3.3V) 40 40
Total 615 2513
Here the in line status n.a is due to the unsuppoted power model 1400AC
swamy
