RJ-45 patch cables for Gbps
Answered Question
Sep 6th, 2006
  • Green, 3000 points or more
Are Cat-5 patch cables OK for Gbit (assuming that they have all 4 pairs cabled, of course), or do I need to buy some Cat-7? I know that Gbit uses the same clock rate as 100 Mbps, so I would have thought that Cat-5 would do. Can anyone tell me differently, or point me to a doc?
Kevin Dorrell
Luxembourg
Correct Answer by vijayasankar about 10 years 11 months ago
Hi Kevin,
Looks like there will be some problems if CAT5 is used for Gigabit, as the electrical specifications for Cat5 cables are designed keeping 100 mbps transfer rate.
Cat5E is the one which is designed for gigabit transfer rate.
Have a look at these URLs,
http://www.connectworld.net/syscon/support.htm
http://www.lanshack.com/cat5e-tutorial.aspx
Im not sure about Cat-7, but it looks like it will be using a different connector, than the standard RJ-45.
So, it would be better to go for Cat5E or Cat 6 for your setup.
-VJ
Overall Rating: 4 (2 ratings)
Correct Answer
vijayasankar Wed, 09/06/2006 - 01:34
  • Silver, 250 points or more
Hi Kevin,
-VJ
Kevin Dorrell Wed, 09/06/2006 - 02:51
Hi VJ,
Thanks for those links. THey are just what I needed.
Kevin Dorrell
Luxembourg
