09-06-2006 11:06 AM - edited 03-05-2019 12:02 PM
Can someone clarify what I am missing ?
(3) routers connected. Please find attached the file showing 'show run' from all three routers and diagram.
I try to ping from RouterC (150.1.1.2) to workstation 152.1.1.3 and it times out.
On RouterB I put a default route and I also include the ip route command to deliver traffic destined to 152.1.1.0 on s0/0. However, I am still unable to successfully ping from 150.1.1.2 to 152.1.1.3.
09-06-2006 11:27 AM
You are missing some routes. Can you remove the static routes you have in place and add the following.
Router A:
ip route 150.1.1.0 255.255.255.0 195.1.1.10
Router B:
ip route 152.1.1.0 255.255.255.0 195.1.1.4
Router C:
ip route 152.1.1.0 255.255.255.0 150.1.1.1
Hope this helps!
Sundar
09-06-2006 05:20 PM
That did it.
The part that I was missing is that I thought that because I was able to ping RouterB e0/0 interface from RouterC, I thought that meant that RouterC knew how to get to RouterB. However, the way it works is that RouterC also needs to have the default route so that the traffic to 152.1.1.0/24 will know which path to flow;e0/0 on RouterC.
Thanks much Sundar.
09-06-2006 05:47 PM
Configure the following on Router B:
int e0
no ip redirects
On the host (152.1.1.3) your default gateway should be set to 152.1.1.1.
If you are still having problems try pinging the host from Router B. If that works can you post the output of traceroute from router c to the host.
09-06-2006 05:50 PM
Glad to hear that :-)
Ignore the last post as I thought you were still having problems.
