NAT - Routing issue
Sep 6th, 2006
Ok - here is the setup.
Cisco 7204.
Ethernet 1/0 - private LAN interface 10.42.111.254 255.255.240.0
Ethernet 1/2 - Connection to parent company - 10.220.17.250 255.255.255.224
FastEthernet 3/0 - connection to internet 67.X.X.82 and 84 255.255.255.240
Have internal servers which are access from the internet via 67.x.x.82 on various ports.
So I have NAT setup with Ethernet1/0 being inside and FE3/0 outside.
I want to have all 10.0.0.0 traffic that isn't obviously off the E1/0 network, to be shot down the E1/2 interface. Unfortunately I can not get rid of the 'IP route 10.0.0.0 255.0.0.0 10.42.96.0' statement - it says no matching route to delete. I have added a 'ip route 10.0.0.0 255.0.0.0 10.220.17.254' but it still looks at the previous route statement first. any help would be appreciated.
thanks,
dan
pkhatri Wed, 09/06/2006 - 21:01
  • Purple, 4500 points or more
Have you got any 'ip default-network' statements configured ?
Paresh
rajinikanth Wed, 09/06/2006 - 21:28
  • Bronze, 100 points or more
Hi dan,
If the route
ip route 10.0.0.0 255.0.0.0 10.42.96.0'
is no deleting then add a route
with same statement with Administrative distance of 255
ip route 10.0.0.0 255.0.0.0 10.42.96.0 255
Then ur 'ip route 10.0.0.0 255.0.0.0 10.220.17.254' takes preference by router
rAj
