PIX 501 help
Sep 6th, 2006
I have configure the PIX501 to have the following:
Inside Int: 192.168.0.1
Outside Int: 203.123.132.131
From the PIX console, I am able to ping to outside IP ( external IP such as goolgle ..etc ) and I am able to ping to the server connected to one of the server which is having 192.168.0.202 IP. However, from the server side, I am not able to ping out to any of the host reside externally such as google..etc
Need you guys help to shade some lights.
THanks,
vijayasankar Wed, 09/06/2006 - 21:29
  • Silver, 250 points or more
hi,
Can you post the config ( removing the sensitive details, public ip etc) here for us the check.
We would like to check the nat/global/acl/route configurations.
-VJ
Fernando_Meza Wed, 09/06/2006 - 21:32
  • Gold, 750 points or more
Hi .. you need to create a PAT for going out
nat (inside) 1 access-list OUTbound
global (outside) 1 interface
access-list OUTbound permit icmp any any <- allows ICMP
access-list OUTbound permit IP any any <- allows all
I hope it helps .. please rate if it does !!!
andy_saw_18 Sun, 09/10/2006 - 19:50
thanks but I believe there's some routing issue.
pix501(config)# sh route
outside 0.0.0.0 0.0.0.0 203.123.132.1 1 OTHER static
inside 192.168.0.0 255.255.255.0 192.168.0.1 1 CONNECT static
outside 203.123.132.0 255.255.255.0 203.123.132.131 1 CONNECT static
My Linux server routing table:
[[email protected] ~]# route -n
Destination Gateway Genmask Flags Metric Ref Use Iface
203.123.132.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth1
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
