config.text.renamed
Sep 7th, 2006
Hi guys,
I unplug the power of my catalyst 3560 by mistake, then everything gets crazy. The ios image is c3560-ipbase-mz.122-25.SEB4.bin. I lost the configuration file. why?
I have access to the console port and i type show flash, the results are:
config.text.renamed
vlan.dat.renamed
The device lost all the configuration!
I need to reconfifure everything again!
Can you explain me what could be the problem here!?
Thank you.
Overall Rating: 3.7 (3 ratings)
paramvsi Thu, 09/07/2006 - 14:49
Hi Nunos,
The issue is that the configuration files are renamed to a new filename that is not known to the switch in its NVRAM. You need not reconfigure the switch.
Please copy the following commands and paste it to get the configurations back.
rename flash:config.text.renamed flash:config.text
rename flash:vlan.dat.renamed flash:vlan.dat
write mem
reload
After you paste the above commands the output will show the correct filename and the configurations will be back on the switch after the reload.
Hope this helps,
Param
nunoscosta Fri, 09/08/2006 - 08:28
Thanks, but i am not understanding why they get with renamed extension!?
:o|
paramvsi Fri, 09/08/2006 - 10:28
Hi Nunos,
The only way that the config files are renamed is if the user presses the mode button for more than 10 seconds. The LEDs will start blinking after 3 seconds, and after 10 seconds the config files will be renamed and the switch will reboot.
These are the message that occurs:
0:01:21: %SYS-7-NV_BLOCK_INIT: Initalized the geometry of nvram
00:01:21: %EXPRESS_SETUP-6-CONFIG_IS_RESET: The configuration is reset and the system will now reboot
00:01:22: %SYS-5-RELOAD: Reload requested
This is a way to clear the configuration from a reconfigured switch so that normal express setup can be used.
There is a bug related to this behaviour.
Bug Id CSCee75743.
You can check the details of this bug using the following link of bug toolkit.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCee75743&Submit=Search
The possible workaround is In global configuration mode, use the command "no setup express" to disable express setup.
Hope this helps,
Param
rajinikanth Thu, 09/07/2006 - 19:57
Use this command
at priveleged mode
rename flash:config.text.renamed flash:config.txt
Then Copy the running-config to start-up and reboot
Raj
Rolf Fischer Fri, 09/08/2006 - 09:36
unfortunately I don't have an answer to your 'why'-question but a couple of months ago we had exactly the same problem with a 3550.
Our consulter argued somebody did a password-recovery but nobody had physical access to the switch.
I think we're also running the same IOS, I'll check that at monday in the office.
Since the rename- and reboot- procedure it works fine.
Best regards
Rolf Fischer
