Warning message
NM-2V with VIC-FXO card
I have a 2621xm router. Can someone tell me which Network Module I need to get to support either 2 VIC-2FXO cards or 1 VIC-4FXO card. And these hardwares will be use in India so I also need to know which VIC-FXO card I need to get for India. Thank you in advance !!!
I understand the VIC-4FXO is universal but not sure of the VIC-2FXO.
Any helps will be greatly appreciated !!
Danny
gogasca Thu, 09/07/2006 - 15:08
  • Green, 3000 points or more
Those cards work with NM-1V and NM-2V
(Currently EoS)
Customers are encouraged to migrate to the Cisco IP Communications Voice/Fax Network Modules (NM-HD-xx) and associated VICs. The Cisco IP Communications Voice/Fax Network Modules (NM-HD-1V, NM-HD-2V and NM-HD-2VE) support all the features of the current low density voice/fax network modules (NM-xV) while offering significant advantages such as higher port and channel densities and a new generation of digital signal processors (DSPs) with greater memory and processing power
This link contains the info you want.
http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet0900aecd801c595e.html
