Warning message
desai.jaideep Fri, 09/08/2006 - 00:21
  • Gold, 750 points or more
First of all pls tell its for voice or data?
JD
mamta.gohil Fri, 09/08/2006 - 02:13
it is for data jaideep
config may
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
or anything else required
regards
mahesh
desai.jaideep Fri, 09/08/2006 - 02:43
Since you are configuring for data...the config will be "channel-group".
I configure for Rel. or Tata 2Mbps e1 unframed mode like following:
contr e1 1/0
channel-group 0 timeslots 1-31 speed 64
framing no-crc4
linecode HDB3
clock source line
serial 0/0:15
ip add
And this works.
Hope that helps.Pls revert back in caseof any prob.
Pls rate helpful posts.
JD
mamta.gohil Fri, 09/08/2006 - 21:53
dear jd
i think there is issue with provider link
anyway thanks for your support
regards
mahesh
