L2L VPN over TCP
Answered Question
Sep 8th, 2006
Can anyone please tell me if it is possible to setup a L2L tunnel over TCP between two PIX 515E firewalls?
Praveen
Correct Answer by ajagadee about 10 years 11 months ago
Praveen,
Not possible for Lan to Lan IPSEC Tunnels on the Pix.
You could use a feature called "Ipsec Over TCP" but this is for only for VPN Clients.
If you dont mind, could you share the reason for this type of requirement. Thanks!
I hope it helps.
Arul
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Fri, 09/08/2006 - 10:54
  • Cisco Employee,
Praveen,
I hope it helps.
Arul
praveenprakash Mon, 09/11/2006 - 00:08
Arul,
Thank you very much for the reply. The reason is, we have a tunnel running to one of our client sites and due to internet conjestion and/or some routing issues between SPs there is a lot of packet loss happening and the end users are suffering with their appliations. But I assume the packet loss should be taken care by TCP Layer between the hosts.
I am not really sure if tunnel over TCP makes sense but just wanted to check.
Praveen
