Product selection advise please.
im.da.fletch
I have a client that has just installed a T1 line. They wish to retain DSL as backup. I'm looking for a Router with VPN capability, multiple (2) IP input, and 16 port switch. at least 4 need to be 1000 bps. Does Cisco have such a product?
desai.jaideep
Level 5
Level 5
You can look at a Cisco 3825 which has 2 NME in which you can install one NM-16ESW-1GIG and one NM-1GE so that you will have 4GE and 16 10/100 ethernet.
Also If you want to terminate a T1 line on the router, that can be done.
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8016a8e8.html
Hope that helps
JD
Yes, thanks. Looks like that would do it.
Fletch
