Warning message
What causes a port on a switch to have a faulty link?
I am trying to run a distributed simulation on a closed network and I have been having some issues. I moved all of my machines participating in the simulation to the same switch (cisco 2950) but I notice that a few of the ports have faulty links only while the simulation is running. I do not believe that this is being caused by a bad piece of hardware but I am not ruling it out either.
I would like to know what else can cause a link to be faulty so that I can continue my investigation into the problem?
Any help is appreciated and thanks in advance,
Jason
b.hsu Thu, 09/14/2006 - 05:56
  • Silver, 250 points or more
If a port is in the faulty state, it indicates a hardware problem. Issue the show test command for module diagnostic results.
sourabhagarwal Fri, 09/15/2006 - 02:28
  • Gold, 750 points or more
you can run "show post" command to detect any hardware problem on 2950.
