ASA Licensing Question
Sep 8th, 2006
  • Silver, 250 points or more
I just want to know if we bougth an ASA with 1000SSL license and then we bought a fialover do we have to pay again the 10000SSL licensing? Same question for Anti-X and IPS?
THanks,
Overall Rating: 3.5 (4 ratings)
ajagadee Fri, 09/08/2006 - 10:37
  • Cisco Employee,
Mohamad,
Yes, you need to buy licensing for the failover unit as well. Both units should have the same hardware, software configuration, and proper license.
I hope it helps.
Arul
m-haddad Fri, 09/08/2006 - 12:46
Even if the the ASA is running in Active/Standby mode and not in Active/Active mode and there is no disscounted price of the failover?
ajagadee Fri, 09/08/2006 - 13:35
  • Cisco Employee,
Yes, that is my understanding.
I would highly recommend that you contact your local sales team regarding discounts and maybe they can work something out.
Arul
sachinraja Sat, 09/09/2006 - 00:55
  • Red, 2250 points or more
haddad
yes.. u will have to have to boxes which have the same replicated hardware/licenses. ASA pricing is not like PIX firewalls, where the failover unit is half of the price of the primary.. but u have ur own limitations there, where the failover unit cannot be used as a standalone unit at any point of time.... whereas in ASA u can use both the boxes in standalone boxes too...
in ASA, the active and the standby units must have identical software/hardware...
hope this helps.. all the best...rate replies if found useful..
Raj
