Warning message
No ringback when placing Avaya to CCM calls
I have an Avaya TDM phone installation that is integrated to an IPT CallManager network via T1-CAS MGCP gateway. When calls are initiated from IPT network to Avaya network, ringbacks are heard on IPT phones. However, when placing a call from the Avaya TDM phones into the CallManager IPT network, no ringbacks are heard (IPT phone rungs and calls proceed successfully). Below is my gateway config:
controller T1 0/0/0
framing esf
linecode b8zs
ds0-group 1 timeslots 1-24 type e&m wink-start
mgcp
mgcp call-agent 10.164.117.199 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 999000199 pots
service mgcpapp
port 0/0/0:1
SAMPLE CallManager Gateway config:
MGCP T1 Gateways : Qty 1
End-Point Name -- S0/SU0/[email protected]
Description -- [email protected]_GW1
Device Pool PUE_DP
Media Resource Group List None
Location None
Top
MGCP Analog FXO Gateways : Qty 4
End-Point Name -- AALN/S0/SU1/[email protected]
Gateway Information
Description AALN/S0/SU1/[email protected]-GW1
Device Pool PUE_DP
Calling Search Space None
Location None
Network Locale Unknown
Port Information
Port Direction Outbound
Attendant DN 9400
Product Specific Configuration
Hookflash Timer (50-1550ms)
Inter-digit Duration Timer (50-500 ms)
Input Gain (-6..14 db)
Output Attenuation (0..14 db)
Echo Cancellation Enable
Echo Cancellation Coverage (ms)
Gateway Information
Device Pool PUE_DP
Location None
Port Information
Port Direction Bothways
Attendant DN 0
Any help is appreciated.
Mike.
gogasca Sun, 09/10/2006 - 10:50
  • Green, 3000 points or more
I would first suggest addedd the two following commands:
"mgcp bind media source-interface
'mgcp bind control souce-interface
We need to verify that the gateway is sending ringback to the PBX now.
Would you capture a:
debug vtsp all
debug vtsp tone
while making a call from a PBX phone to a IP phone. CCM trace will be useful here, could you please send me the calling party number, the called party number, and the exact time of the call with the debug output.
Need to check the RQNT (S: G/rt) in the MGCP process.
If I remember correctly, in the Avaya side for the trunk group type Which one you have: ?Tandem? or ?Tie?.
In the Trunk group parameters in & out signaling: ?WINK/WINK? vs ?WINK/DELAY? ?
Let us know.
I ended up opening a TAC case on this and thought I would pass on the resolution. An MGCP packet debug indicated that the Avaya PBX was sending an extra digit. Although Avaya integration documents on CCO suggested the Avaya trunk be set to "tandem", the TAC engineer found a previous case with similar symptoms that was corrected by setting the Avaya trunk to "tie".
We had the Avaya trunk changed to "tie" and that cured the problem!
Thanks for your reply and time on this.
Mike.
