7941 Phone Button template on CCM 4.2(3)
Sep 10th, 2006
Has anyone got an overflow error message when trying to ad the customized 7941 phone template on CCM 4.2(3) devpack 3.3?
By default, the standard 7941 phone button template come with 1 Lone and one speed dial, but our environment here need a two-lines phone. While ny other model can have several version customized button templates but no 7941. Please kindly sugest on what I should check in order to acheive adding the 7941 phone button template.
nvong Fri, 09/22/2006 - 19:14
Hello all,
I have let the TAC engineer and Developers took care over the case and they solved this issue for me already. The problem is a missing of line 2 record in standard 7941 Phonebutton SQL table. If you already have your case opened please refer the case number 604361587 to your TAC engineer so he/she can contact the one that took care over my case for the solution.
