Inspect Message Submission (TCP/587)
Sep 11th, 2006
Does the new PIX 7.0 software also supports/inspects (SMTP email) submission port 587, RFC 2476 - Message Submission.
If yes, what modifications need to be done in configurations.
vmoopeung Fri, 09/15/2006 - 06:13
  • Bronze, 100 points or more
There is no difference between whatever ports are used.Its the same access list configuration to allow port 537.configuration should be done only on the email clients for the port 537 so that clients can start sending messages on port 537 instead of port 25.
pavlosd Tue, 09/19/2006 - 23:12
what about the inspection engine? I read that the new RFC supports for SMTP/SSL.
