Two PVDM2-16 modules do not work together
Sep 11th, 2006
I've installed two PVDM2-16 modules into Cisco 2811 router. But they do not work together.
"sh diag" shows them normally:
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 3.2
Part Number : 73-8538-04
PVDM Slot 1:
Hardware Revision : 4.0
Part Number : 73-8538-05
"sh voice dsp" shows channels only for the first PVDM2 card.
Why do these two cards not work together?
Thanks a lot for your help!
gpulos Mon, 09/11/2006 - 06:10
  • Blue, 1500 points or more
have you enabled the DSPs to be used on the second card?
use the following commands to enable DSP services for the second voice card:
router(config)# voice-card 'X' ( X = the voiceCard slot DSPs are inserted into)
router(config-voicecard)# dsp services dspfarm
if you still have problems, please post your config so we can verify it is correct or provide the corrections for you if it is not.
kritskiy_monstr Mon, 09/11/2006 - 07:00
I cannot use voice-card 1:
ccme-luk(config)#voice-card 1
% Invalid input detected at '^' marker.
But PVDM2 is present in slot 1:
sh diag
ccme-luk# sh diag
PVDM Slot 0:
Board Revision : A0
Deviation Number : 0
Fab Version : 03
PCB Serial Number : FOC09430EQJ
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-16
Version Identifier : NA
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 EF 41 03 02 82 49 21 5A 04 42 41 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 30 39 34 33
0x20: 30 45 51 4A 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 31 36 89 4E 41 20 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC10165SED
RMA History : 00
Processor type : 00
Version Identifier : V01
0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 31 36
0x20: 35 53 45 44 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
On this router 10 analog FXO/FXS ports are present. Two of them show a steady light (like there is not enough DSP resources).
Full config is attached.
