Warning message
question about IPS log
Sep 11th, 2006
hi,could ASA firewall with IPS moudle send the intrude event log to the log server automatically when intrude event occured,if it could,how to config?
thanks a lot!
Overall Rating: 4 (1 ratings)
Fernando_Meza Mon, 09/11/2006 - 19:59
  • Gold, 750 points or more
Hi .. you can do this by enabling SNMP traps on the sensor. You will need to configure the request-trap action on the signatures .
You can access this from the IDM under Configuration tab -> SNMP
I hope it helps .. please rate if it does !!!
