Warning message
Edison Ortiz Tue, 09/12/2006 - 06:03
  • Hall of Fame,
    Founding Member
Darnell,
The switch will come with an IOS similar to a router. The syntax will be the same, just make sure you enable routing by typing
ip routing
while in config mode.
