Warning message
rajinikanth Tue, 09/12/2006 - 08:33
  • Bronze, 100 points or more
hi,
Use the command in global configuration
to remove ur existing defualt gateway
When ip routing is enabled on the Cisco router
router(config)#no ip default-network x.x.x.x
and add this command
router(config)#ip default-network x.x.x.x
and
when ip routing is disabled on the Cisco router.
use this commands
router(config)#no ip default-gateway x.x.x.x
to remove existing default router.
add using
router(config)#ip default-gateway x.x.x.x
Raj
Edison Ortiz Tue, 09/12/2006 - 08:34
  • Hall of Fame,
    Founding Member
The default gateway is usually represented with the command
ip route 0.0.0.0 0.0.0.0 [default gateway ip]
However, the default gateway can also be injected from remote routers by using dynamic routing protocols.
If you post the output from typing
#show ip route 0.0.0.0
we can help you better.
