Advertise route as OSPF, but I see it as "EIGRP" ?
Sep 12th, 2006
Sorry if this is a stupid question but I don't understand well why I am able to see route
D 152.1.1.4/30 on RouterD.
Basically the network 152.1.1.4/30 has been advertised via OSPF on RouterC interface. However, that was not advertised there as an EIGRP route...
How come I am able to see it on RouterD as EIGRP ?
Please find attached complete run config.
Please note I am doing one-way redistribution EIGRP->OSPF. Therefore in my view that doesn't justify the EIGRP route for 152.1.1.4/30 on RouterD.
RouterB so]===[s0 RouterC s01]===[s0 RouterD]
RouterB s0=152.1.1.5/30
RouterB S1=152.1.1.6/30
RouterD S0=152.1.2.2/24
From RouterD:
Gateway of last resort is not set
152.1.0.0/16 is variably subnetted, 3 subnets, 2 masks
C 152.1.3.0/24 is directly connected, Loopback0
C 152.1.2.0/24 is directly connected, Serial0/0
D 152.1.1.4/30 [90/2681856] via 152.1.2.1, 00:01:58, Serial0/0
Edison Ortiz Tue, 09/12/2006 - 20:10
  • Hall of Fame,
    Founding Member
Can we see routerD and routerC running config ?
news2010a Tue, 09/12/2006 - 21:41
Hi Edison,
It is attached.
However Sundar hit the nail;
I advertised using the inverse mask and I was no longer able to see the route onto RouterD (EIGRP).
Thanks !
jackyoung Tue, 09/12/2006 - 22:04
  • Gold, 750 points or more
It was because you include S0/0 of router C in EIGRP by the network command. The 150.1.1.4/30 fall into 150.1.0.0 of EIGRP. If you want to enable S0/1 of router C only. You can use below network in the EIGRP of router C.
network 150.1.2.0 255.255.255.0
Hope this helps.
