DCD=up DSR=down DTR=up RTS=up CTS=up
Answered Question
Sep 12th, 2006
Can anybody give me links from where i get meaning of
in details for troubleshooting prpose
Mahesh
Correct Answer by jolmo about 10 years 5 months ago
Hi Majesh
DCD - This signal is output by the DCE to indicate that a valid carrier has been detected.
DTR - This signal is output by the DTE to indicate that it is ready for communication.
DSR - This signal is output by the DCE (in response to DTR) to indicate that it has been switched on and connected to the communications channel.
RTS - This signal is output by the DTE to indicate that it is ready to send data.
CTS - This signal is output by the DCE to acknowledge RTS and to indicate that it is ready for data transmission.
For troubleshooting this might help:
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a758d.shtml
Correct Answer by lgijssel about 10 years 5 months ago
I think you should check the chapter on dialing solutions of the IOS configuration guide:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/prod_configuration_guide09186a008017d8e6.html
Hope this helps you out.
Leo
Overall Rating: 5 (2 ratings)
Correct Answer
jolmo Wed, 09/13/2006 - 01:41
Hi Majesh
