Warning message
QOS for Policing Ethernet Traffic on Catalyst 3750
Sep 13th, 2006
Hello!
I am running a Cisco Catalyst 3750 with IOS c3750-ipbase-mz.122-25.SEB4.bin
Since we've deployed these switched on our Metro Ethernet network, we are now needing the capability to police/rate-limit the client's ports.
I've done examples on Cisco's docs about QoS in 3750 but can't seem to get it right.
I have mls qos enabled
QoS is enabled
QoS ip packet dscp rewrite is enabled
I have placed this configurations to try to limit client traffic
class-map match-all ANY
match access-group 1
access-list 1 permit any
policy-map POLICE-TO-2MB
class ANY
police 2000000 375000 exceed-action drop
I then apply this to the client interface
interface GigabitEthernet1/0/5
description Link to Customer
switchport access vlan 12
service-policy input POLICE-TO-2MB
end
apparently, the client's input traffic, meaning his upload to me is still exceeding 2Mbits, actually it is still at 95Mbits/sec so I am really confused.
Hope you guys could give me some pointers on how to police all type of traffic on this interface.
Thanks!
Overall Rating: 2.5 (2 ratings)
tiagocarrijo Wed, 09/13/2006 - 04:26
You can't use input police in normal ports in the 3750.
You need to use de ES ports.
So you can do an VLAN police rate.
sherwinang Wed, 09/13/2006 - 09:09
Pardon me, but what do you mean by ES ports? I hope you could point me to a documentation about this or probably a simple example. Thank you.
shaner Wed, 09/13/2006 - 09:37
apply the service policy to interface vlan 12, not the layer 2 switchport interface GigabitEthernet1/0/5.
This should work.
also to ratelimit egress traffic use the srr-queue bandwidth shape command. You can't do a service policy output on the 3550/3750. THere is a hardware limitation.
tiagocarrijo Thu, 09/14/2006 - 03:52
An ES port is found on 3750 Metro switches.
If you have the 3750 standard, you will need to aply in the vlan.
