09-13-2006 06:14 AM - edited 03-03-2019 05:00 AM
I need some info about jumbo frames support on Cat2950 and 3550
I've seen on CCO that 2950 support babygiant of 1530bytes and 3550 2000bytes...are this info still valid or in latest IOS they are enhanced ???
Only Cat6500 support 9000 bytes jumbo ?
Saluti
Omar
Solved! Go to Solution.
09-13-2006 12:57 PM
Omar,
The numbers that you mentioned for the 2950 and 3550 hasnt changed with the newer codes.
Please refer the below URL for Jumbo Frames Support on Catalyst Switches:
http://www/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml#c2
I hope it helps.
Arul
09-13-2006 12:57 PM
Omar,
I hope it helps.
Arul
09-13-2006 09:39 PM
You can classify the Catalyst 2950 series switches into two major groups, where one supports baby giants (up to 1530 bytes), but the other does not. However, this refers to traffic that flows through the switch. Packets destined to the management (VLAN) interface can support only 1500 bytes.
Please check this link for more information and configuring
Raj
