Auto Attendent in Cisco CallManager Express
Sep 14th, 2006
I have a problem regarding B-ACD (Basic Automatic Call Distribution) in CallManager Express 4.0 with Cisco IOS 12.4(4)XC4.
For example:
application
service aa
! defines the application-name of the AA script as aa
paramspace english language en
! specifies language as English
paramspace english index 1
paramspace english location flash:
! declares location of audio files
param service-name queue
Problem: Now the problem is when i enter Param command in order to implied parameter then i got
Warning: parameter service-name has not been registered under queue name space..
Your prompt assistance in this regard will be highly appreciated.
Chris Deren Fri, 09/15/2006 - 06:27
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
The message does not cause any issues, it is expected. Are you having issues with your script? Make sure you inculde all parameters even the one you think you don't need. Also, make sure you call the application service from incoming dial-peer.
HTH, please rate all posts!
Chris
