Warning message
SRST & Fallback
Sep 14th, 2006
We are having a issue with our Cisco 2811 VoIP routers (C2800NM-SPSERVICESK9-M), Version 12.3(8)T8). SRST works fine when we initiate a fall back by brining the circuit down. However, if we initiate a power failure or reload the router it will use the dial-peers intended for fall back instead of MGCP. The router registers properly with CCM v 4.1(3)SP1. So when you call it rings once then goes to fast busy.
MGCP:
dial-peer voice 999010 pots
application mgcpapp
port 0/1/0
FALLBACK:
dial-peer voice 9901 pots
incoming called-number .
port 0/1/0
What would cause the router to use the fall back dial peers instead of the MGCP dial peers? Thanks!
Overall Rating: 5 (1 ratings)
gogasca Thu, 09/14/2006 - 18:18
  • Green, 3000 points or more
Use only 1 dial-peer, when mgcpapp is not available it will fallback to default app, in this case H323,
So you only need sth like this:
application mgcpapp
port 0/1/0
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a00803927ae.html#wp1352310
dmckelvey Tue, 09/19/2006 - 08:10
This did resolve the issue. Thanks for you input.
