Fax Transmit Error
Sep 15th, 2006
Hi Expert,
I have a problem when sending a fax to PSTN. This is a logical connection.
Fax-PSTN-NECPABX-VG-SatelitLink-CallManager-ATA-Analog Fax Machine
but if i try using this one
Fax-NECPABX-VG-Callmanager-ATA-Analog Fax Machine
it's working
We using g729 codec
Can somebody give me a advice to resolve this.
Best Regards
Andri
b.hsu Thu, 09/21/2006 - 06:14
  • Silver, 250 points or more
I think it oculd be because of the configuration issues with PSTN,check the setting for PSTN network
Aaron Harrison Thu, 09/21/2006 - 06:18
  • Community Spotlight Award,
    Member's Choice, May 2015
The first connection has both a satellite link and a PSTN connection - either of which could be the source of the problem.
Try to rule out each of these in turn, then concentrate on whichever seems to have the problem.
Aaron
Please rate helpful posts...
