Restricting the network view
Sep 15th, 2006
How do I restrict the access of my network view to certain devices?
Bit detail
Out of 300+ sites i have outsourced 100 sites to 3rd party to manage my network
Now I want to give them a network view by restricting to certain devices to view only
Want I have done I have created topology groups with those devices. Its works fine for me.
Now I want restrict that user from viewing other groups as well as layer 2 view.
The user is locally created
Joe Clarke Fri, 09/15/2006 - 10:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Without ACS you really can't restrict much. You can make groups private, but you cannot restrict access to the underlying devices unless you integrate with ACS. Note: even with ACS integration, the layer 2 view cannot be restricted, but the user will only be able to see the devices for which they have access when viewing the layer 2 view.
