Warning message
Load Balancing over Multiple IPSEC SAs
Sep 15th, 2006
I need to load balance IPSEC with GRE over multiple T1s. My current solution is to use two routers, one to hold the physical T1s and the other to form a single SA back to the home router. If I use one router, the traffic does not load balance over the multiple SAs that are formed to the home router. Is there a way to bundle the T1s into a single, virtual interface so that I only use one SA?
umedryk Thu, 09/21/2006 - 08:26
  • Bronze, 100 points or more
IPSec is supported with process and fast switching. To get load balancing with the same DA/SA pair the router must be process switching. If the performance of process switching is enough, then you can do it.
